will these wheels fit???
i just got a great deal on some Lowenhart LD5's for my 01 IS the fronts are 19x8.5 with a 32 offset and the rears are 20x10 with a 26 offset will they fit? and what size sidewall would i need to get, to get the rears to fit? the fronts already have 235/35/19 which are practically new. thanks for the help
Not easily.
8.5 +32 is 10mm past the front fenders. You would have to run a 225 and roll the front fenders and HOPE that camber tucks them under. And you'll have to have stiff springs.
10 +26 is 33mm past the rear fenders. You are going to have to roll and pull the rears and run a 225/30/20 tire.
I don't think it is worth it. Unless you are slammed with a lot of negative camber, the wheels are going to stick out ALOT. And it will be ugly.
Look for ill roller. He is running a 10 +25 with a 225 in the rear.
EDIT: This is ill roller's car.
http://my.is/forums/f90/mini-photosh...-flush-372530/
![](https://i193.photobucket.com/albums/z291/ajgillett/IS300/IMG_2996r.jpg)
