GS400 wheels on IS300?
Hi,
I'm just wondering if the GS400 5 spoke 17" wheels will fit on my Sportcross Wagon. I believe they are 17x8 but I'm not sure of the off set. Can anyone verify this?
cheers
cheers
I have done more researching and I don't think that it will fit properly. You will need to get spacers to clear the brake calipers....since it's such a high offset on a 17x8 rim. See the stock 17" IS wheels fit pretty aggressively towards the calipers already with its 17x7 +50...so the gs400 8" width may be an issue. Something you might want to consider...
Keep in mind though..I am no expert..This is just from researching a bit. Maybe more people can comment on this.
It will not fit properly. Calipers will hit inside of wheels. Will need at least 5mm spacers to correct this
bmgs400
Wheels, Tires & Brakes Forum
11-17-05 11:41 AM
