Offset question
I have a first gen is300 lowered on tein springs and I'm looking to pick up rims. I found a set that is 18x8 +25mm offset wondering if that would fit my car? Please lmk thank you
Mark
Mark
The rears will work without any issues, if its 18x8 all around.
But for the fronts, eh...here read all about this post and learn![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
http://my.is/forums/f95/hella-flush-part2-326782/
P.S. if your not signed in over there, just use my username as a referral. Its the same over there.
FYI... Also, just do research on the wheel specs in the wheel/tire section. There are many stupid Aholes over there that will give noobs a hard time(flame).
I ran 18x8 +13 in the front on stretched tires. Depends on what tire size you use it can work. I had 215/35 in the front slammed on Tein flex. I had to do a little fender roll on mines though. rears should fit at ease. I used 18x9 +23 in the rear with a roll n it had no problems. 225/40 slammed more than the front haha.
