is300 with r154
hi, ive tried search function but no luck ......is there any one on here running a R154 transmission on their IS300 ................this model trans came from a 91 supra turbo with a 1jz motor .....what id like to know is did it need to use a shifter extension and if so where did u buy it from.......thanks for your help
i'm about to do the same thing and from what i've been finding out is that you do , or if you could get it from a soarer that would work perfect i've been told, but like you i'm still tryin to find one
Head on over to my.is and check out the Go Faster Forums. There are tons of threads covering the swap, including this one.
http://my.is/forums/f114/r154-swap-a...w-here-346834/
