headlight question
hiya there,
Im wondering if the new IS300 (2002), have zenon lights or HID lights on them?
Or are they just normal lights?
Because, if you turn on your headlights, the first few seconds it's bright(looks like zenon) but then after awhile, it doesn't look that bright.
And the other thing is, if the headlight is painted, does it reduce the intensity of the light?
getting the smoked JDM headlights cost like 550,!!!!!!!!!!!
thanks alot,
viz
thanks alot,
viz
Originally posted by vizcounty
hiya there,
thanks alot,
viz
hiya there,
thanks alot,
viz
All reports so far are that painting the headlights does NOT cut light output. But note that you DO NOT paint the round reflector area around each bulb. If you paint that, you'll definitely lose a lot of light output.
The JDM headlights, btw, are not HID lights, but use regular halogen bulbs. If you're going to paint yours, consider painting them body color. Check out this site, and go to the second page of photos:
http://uk.photos.yahoo.com/bc/twopen...+IS200&.view=t
Bob
the 2002 have a different bulb than the 2001 I beleive if I remember correctly.. how long have you had the car... it takes about 100 horus to break the bulb in and get it to its real color....
you can try gettin a D2R bulb that is 6000k it will be be brighter and look bluer
hi bobm photo,
what im trying to do is to paint the headlight, so it looks smoked(dark), do you have any ideas?
and I heard that I remove the headlight, open and paint it, air might go inside which cause the headlight to be foggy.
is that true?
Thanks,
viz
is that true?
Thanks,
viz
While I hate to point you to another site, check out is300.net/forum, and do a search on painting headlights, or painted headlight. Theres a lot of info there, including fairly detailed instructions and references to a shop (in So. Cal, I think), that will split them, paint them, and re-seal them. (And they'll work mail order, if you can afford to be w/o your headlights for a week or two).
Air gets into your headlight any time you change a bulb. That's not the problem. The issue is moisture getting into the headlight. It appears that, as long as you seal the unit well after re-assembly, condensation isn't a problem.
HTH,
Bob
HTH,
Bob
