My is300
yea the buttons dont even click anymore. your suppose to press either 1 or 2 to have the positioned to ur settings but when i press the buttons nothin.
oh ok that was the problem i had to replace the old one for a new one. thank you! I like the is300 pic i have the same ffront lip but i just dont have the sealent so it dont lok as clean as your do do u know where i can get that?
I found the part number for the gasket I used on my rear lip. It's a rubber T gasket used in a couple Toyota applications I think. One piece is long enough for the entire rear lip.
Toyota PN #76875-06020-C0
Like stated before, this is the molding piece I used for my front lip, you need 2 of them to do the entire front lip.
Toyota PN #61783-35071
These are just the pieces that I have found and used, there are probably more and other applications as well.
OH, and those are BLACK. I don't know what color car you have, but I need to change mine to gray.
Supposedly, this is for gray #76878-02020-BO. I don't know for sure though. But I was told it was the same as the shorter black just gray. So you'd still two of them.
Mine are rubber gaskets from Toyota.
You could probably use #76875-06020-C0 for the front lip if you didn't want to buy two of the smaller ones. I bought two smaller ones though.
