Headlight adjustment??
Has anyone succesfully adjusted the vertical aim on the low beams? I've stuck a screwdriver in there and twirled it in both directions, but nothing seems to happen. And I think my lights are definitely aimed too low.
If you've done it, which direction raises the lights and which lowers them (clockwise or counterclockwise turn of the screwdriver?)
Thanks.
Thanks.
They are, but there's an adjustment screw on the back of the headlight assembly, that I *THINK* adjusts the center point within the auto leveling system. Take a look in your owners manual.
I finally figured it out. The owners manual describes the procedure, but leaves one thing unclear. There are two adjustment points on each headlight assembly. The OUTER ones adjust left/right alignment. The inner ones adjust vertical alignment. This isn't clear in the owners manual. Once I started adjusting the right ones, it proved to be very easy.
