IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Wow another offset Question from a noob
Old 04-12-10, 09:25 PM
rockstar69
rockstar69's Avatar
Cool Wow another offset Question from a noob
Hello I am new to the forums and recently purchased a 2003 is300 sport design. I am in love with the work emotion wheels but dont really want to spend the cash so I found some Drag DR-31's that are identical.
The 18x8's only come in 2 offsets +48 and +38
Tire size would be 225/40/18 unless someone tells me I should go different
The car will be lowered on tein h tech springs so -.7 on the front -1 on the back(I do believe)
Which setup would work the best and not sit in to far, but not require any modification to the vehicle.
Any help you guys can give me would be awesome.
I did try to search I just wanted to get an answer based on my application, and you guys know these cars better than anyone else I have found
Old 04-12-10, 10:39 PM
anotherLS
anotherLS's Avatar
+38 and no mods to the fender needed, tire size is fine also
Old 04-13-10, 06:55 AM
rockstar69
rockstar69's Avatar
Thumbs up
Thank you so much for the quick response it is greatly appreciated
Old 04-13-10, 08:39 AM
iSuxeL
iSuxeL's Avatar
If you want to be more flush I'd recommend getting 18x9.5 +38 but you're going to need to stretch. Here's an old picture of my old wheels on my friends IS300, it's 19x9.5 +41 I think
Old 04-13-10, 11:12 AM
rockstar69
rockstar69's Avatar
Smile
how much difference would a +35 make, I misread the wheel info and they are 18x8 +35
Old 04-13-10, 12:28 PM
sway162
sway162's Avatar
You will be straight. You might rub a teeny bit up front on a full turn but nothing that will make you have to roll fenders.
Old 04-20-10, 09:17 PM
rockstar69
rockstar69's Avatar
Default Thanks So much
Thanks to all of the members that helped me out with this inquiry, I ordered my wheels today Drag DR-31 18x8 +35 with some 225/40/18s the wheels are matte gun metal i wanted a look like Kirill Y.'s is but figured i would at least change the color to match all of the sport design stuff
Thanks again for all of those that made suggestions
Old 04-21-10, 01:17 AM
anotherLS
anotherLS's Avatar
come check out our monthly SD Club Lexus meets...its in the socal section
Old 04-21-10, 10:52 AM
MY2J
MY2J's Avatar
you were better off going with the +48 offset. Our cars come with FWD offsets (+50 stock) so anything close to those numbers is the "safe" way of doing things. the people that suggested the +35 offset was a personal preference. you will most likely need to roll your fenders now.
Old 04-21-10, 01:56 PM
sway162
sway162's Avatar
Maybe a tad bit up front but it's straight for the rears. I have 8 +35 w/225 and no rubbing.
Old 04-21-10, 07:32 PM
rockstar69
rockstar69's Avatar
Smile
If I have to roll so be it, money is already spent, its better than having that crappy inset look with the nice front lines of the car, plus these wheels will only be on for the summer anyway. I would love to come to the SD events to bad my SD is South Dakota.
Old 04-25-10, 02:34 PM
pigeon83
pigeon83's Avatar
The sportdesign had a specially tuned suspension and the 11 spoke alloys. Any rubbing isn't worth it. They designed the car to fit specifically sized wheels.
If you wanted to do a worthwhile performance modification, you could get forged alloy wheels with ultra high performance tires like Pilot Sport A/S plus(I just got them and I love them) instead of bigger but not necessarily better wheels.
Old 04-28-10, 10:00 PM
rockstar69
rockstar69's Avatar
Default Save the pain
So I got the wheels on monday, put them on the car and rolling wasn't neccessary, but buying a set of vertex 15mm fenders and gutting the inner fender would probably do the trick along with shavin the rear fenders. Lucky enough discount tire direct is taking them back. If you want wheels to stick out 1.5 inches or so in the front these are the wheels that can make it happen. When I talked to the guy at discount he said they should have never let me order them, oh well live and learn, and I will definately buy from discount again they are awesome.
2jz_drifts
07-07-11 01:10 PM
Moosepower
14
03-28-11 04:47 AM
abobiznow
07-08-09 12:26 PM
GS3Tek
Wheels, Tires & Brakes Forum
14
04-27-05 09:36 PM
CP_Ree
02-12-05 08:41 PM
Quick Reply: Wow another offset Question from a noob
