2002 IS300 o2 sensor bank 2 question
hey all
i have an 2002 IS300 5-speed with no name brand headers.. now its throwing a code
P0161 - O2 sensor bank 2
i believe that is the sensor that plugs onto the stock precaton the headers..
i want to know what i can do to not trigger the CEL..
Expert Gurus. help and advice is needed.
thanks
thanks
You can try the anti-fouler method or get an o2 simulator.
A simple search will answer your question. This is from the 2GS section but exact same applies to 1IS.
https://www.clublexus.com/forums/per...simulator.html
im actually searched the forums.. im familiar with the search button.. i typed in my CEL triggered codes in the search cause thats what it refers to . but nothing showed up..
as for the wrong section.. Mods, please move this to the right section
thanks
thanks
The TokenSolutions product is your best bet in resolving this cell, been running it for quite awhile now with no issues
Also I created this image a little while ago when I put my megan headers on, found all the info spread out and not exactly easy to understand so I decided to put it all into one.
nymidas, that is an EXCELLENT image. if you made that, i highly suggest you watermark it. i wish i had that a few days ago when i was trying to figure out my own O2 sensor problems https://www.clublexus.com/forums/is-...nspection.html.
in the past few days i've gobbled up a lot of information regarding O2 sensor problems. from what i've read, an O2 sensor blocker will only work if you have problems with the cat or lack thereof. if you have any codes other than P0420 or P0430, i doubt a blocker will do the trick.P0420 and P0430 address the cats [ONLY] on each bank specifically.
P0161 is a heater circuit code. you might need a new O2 sensor unless you can find a sim that will simulate the heater signal.
