fuel pressure and no2 question
when using NO2, has anyone hooked up an o2 voltage to see how rich or lean its running with the T fitting... to see if you need any additional pressure or volume to run a 100 shot?
and does anyone know what stock fuel pressure is rated at???
stock fuel pressure
the stock fuel pressure is set at 44-50psi and 21psi residual after engine shut off.
also if you are worried about fuel pressue and volume you can always upgrade to a tt supra fuel pump. powerhouse has a trick system, check it out
WOW, this is diff-cult question... How about you call up a pyschic.. only $9.99 per minute! Cleo knows it all! Call today!
1800Rice-IT-UP!
this is your last warning.. thank you and have a nice day
1800Rice-IT-UP!
Interesting you make fun of this as rice when you want to install blue mood lights in your BMW.
Here's a link
Here's a link
Here's a link
Here's a link
