IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
key locked up
Old 09-14-10, 07:23 PM
03LexIS300
03LexIS300's Avatar
Originally Posted by chunktwo
i bought a key from my.is. i thought it was an OEM key. I am still not sure cause of the way it looked/felt.
I heard that some ebay keys have steel in them and that locksmiths won't cut it. After reading that i took a magnet to it and sure enough it didn't stick. The locksmith did the same test and confirmed there was not steal in it before cutting it.
Found a local locksmith (specialty in locks/keys) to get it cut and the key works like a charm. Cost $10 for the key shell and $23 to get it cut.
it was cheaper then getting it from the sewell online site which was $75 or so for just the key shell and have it cut.
the back of this key looks nothing like the two i originally had. the plastic is also not as "smooth" and it looks/feels more textured. So i was suspicious if its an OEM key. but in any event the transponder fit just fine and key works on the door, ignition and trunk.
that key shell is an ebay one. if it was genuine lexus it would say FCC: ID and such on the back.
Old 09-14-10, 08:45 PM
llllllllll
llllllllll's Avatar
$10 ebay backup is better than no backup key at all
Got a link to the ebay seller?
That key actually doesn't look too bad..
There are lots of ebay sellers, I don't want to pick the wrong one and get something worse than yours...
Old 09-14-10, 08:54 PM
03LexIS300
03LexIS300's Avatar
no doubt they are good, when i bought my car i had one new lexus key, and an old one that was broken, but it had the transponder and all i did was buy a shell for $10 and get it cut for $30 replace the $3 battery in the transponder and for $43 i had a new (Ebay) lexus key but it works like a charm, works just as good as my genuine lexus key i have. and they both say lexus so im happy
Old 09-14-10, 09:13 PM
llllllllll
llllllllll's Avatar
Can you look in your ebay history and tell me who the seller was?
This one is just the shell cover i think.
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
This one looks good, but the key is gold looking?
Maybe it is not steel like someone mentioned and maybe it will break?
I don't care which is cheapest since they're all like around $10 or less.
I just want a good one that's not going to break easily
Or should I just do eenie-meenie-miney-mo?
Old 09-14-10, 09:38 PM
03LexIS300
03LexIS300's Avatar
i bought mine off CALLEXUS heres a link
it is gold color, and not steel. but with some use it turns silver. my original lexus key is not steel either, but it is like a polished aluminum not gold. but that is the only difference i see is the color of the ebay key compared to OEM.
Old 09-14-10, 09:46 PM
llllllllll
llllllllll's Avatar
ordered, thanks
Old 09-14-10, 10:06 PM
03LexIS300
03LexIS300's Avatar
ordered, thanks
no problem man anytime
Old 09-15-10, 06:50 AM
chunktwo
chunktwo's Avatar
that is what i suspected, that it was not an OEM key.
Call around your area to see who can cut the key. took me a little bit in the DC metro to find a place that was willing to do it and had the ability to do it.
btw thanks for the link.. ill know where to go next time =)
Just realized you are from VA.. if you are in NOVA - the place i went to is called Baldinos. If you bring in your own key its only 22.50+tax to get it cut. just FYI if you ever need to get another one cut.
Old 09-15-10, 10:38 AM
03LexIS300
03LexIS300's Avatar
I took my key out near my local DMV to a place called Precision Locksmith. they can look the VIN up and cut the key or cut it based off the old key, i just gave them the old key and a few minutes later and $30 and a $3 transponder remote battery I was on my way with my new key. they did a great job.
Old 09-15-10, 01:03 PM
llllllllll
llllllllll's Avatar
Cheap Ebay Key + DIY remote programming = WIN!!!
DIY: How to Program a NEW Transponder
http://www.isfanatics.com/forums/showthread.php?t=3304
Old 09-15-10, 07:34 PM
03LexIS300
03LexIS300's Avatar
haha yes for sure and a much cheaper option to getting a whole new key!
Old 09-15-10, 08:30 PM
llllllllll
llllllllll's Avatar
yep
Now if only I can find another transponder
Old 09-15-10, 08:46 PM
03LexIS300
03LexIS300's Avatar
yep
should be able to find a few on ebay. i believe used ones will work you will just have to reprogram them to your car.
Old 09-15-10, 08:49 PM
llllllllll
llllllllll's Avatar
yah i looked on ebay and didn't see anything
only the empty transponder keys
Old 09-15-10, 09:34 PM
03LexIS300
03LexIS300's Avatar
man your right, nothing on ebay
Quick Reply: key locked up
