key locked up
when my wife got home last night she could not get the key out of the ignition. it is stuck on acc. it will not go to lock or go to start it. the radio come s on still. i unplugged the battery. i barely could get the key out . what do i have to do to get the cylinder out. is it possible to do it at home and replace it with another one?
just bought a new cylinder with key. 120 bucks delivered from lexus. toyota 30 miles away said they will instal for 100 and program key for 60. a tow to toyota will probably be about 50 bucks. 300 plus bucks. yahoo
sounds like a soundproof plan, sounds like a very good deal considering its a lexus not a honda lol
program it? your old key can be taken apart and the buttons with unlock lock etc. comes out so it shouldnt need any programming. i just ordered a key offline for mine and had it laser cut for $30 and reused my old buttons. sounds like a rip off on the programming
agree on that, i bought a new key shell for mine because when i bought my is300 it had one new lexus key and another old one that was broken in 2. got it laser cut for 40 and new battery in the remote and swapped the remote over and it works just as good as any. the chip in the transponder remote is what the dealership is refering to, and since it is your old buttons and stuff its already programmed to your car, and if you gave them your vin the key should already be laser cut too.
how hard is it to get the old cylinder out? i have a locksmith coming to my house tomorrow. he says he has to drill it out to get it out. 75 to replace cylinder, 75 to come to my house. cylinder cost me 120 delivered from lexus
im not 100% sure on this, but just me judging from previous vehicles i have worked on, your cylinder needs to be in the "acc" position or the "on" position and there should be some kind of plunger on the lock cylinder that you push in and it should pop right out. however if you cannot put your key in or turn the cylinder at all it will need to be drilled out.
i believe he ordered a new cylinder, but gave lexus his VIN number so the ignition is made the same as the old one to accept the same key. i think he got another key because i dont think you can order this assembly without a new key or maybe he broke his, not sure
I dont know, most of people head up to dealer... But I know that there are some guys driving trucks around make keys for some local shops.
I heard that some ebay keys have steel in them and that locksmiths won't cut it. After reading that i took a magnet to it and sure enough it didn't stick. The locksmith did the same test and confirmed there was not steal in it before cutting it.
Found a local locksmith (specialty in locks/keys) to get it cut and the key works like a charm. Cost $10 for the key shell and $23 to get it cut.
it was cheaper then getting it from the sewell online site which was $75 or so for just the key shell and have it cut.
the back of this key looks nothing like the two i originally had. the plastic is also not as "smooth" and it looks/feels more textured. So i was suspicious if its an OEM key. but in any event the transponder fit just fine and key works on the door, ignition and trunk.
