Need Help Asap
So my taillights arent working, i changed out my fuses and still they dont work, all the bulbs are perfect, yet I cant seem to find out what the problem is!!! This is a pain
, I would greatly appreciate if someone can guide me. Thanksss!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
is it your tail lights or your brake lights not working? also, if your tail lights aren't working are your all of your front lights working, and are all of your side marker lights working? could be a bad brake switch mounted to your brake pedal.
Could be the wire harness...
Sometimes clip on the wire harness breaks and you won't get a good connection.
Pull out the tail lights, and check the connection. get a continuity tester
I change the fuses up and they start to work for a couple of days and all of sudden they quit working again, like the brake light as soon as i hit the brakes right after installing the fuse the brake lights quit working. These are led tail lights. And when the fuses stop working also the liecense plate light doesnt work and the one in the rear view windsheld, pretty much the whole back end of the car is out of power.
