IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
self adjust on IS300HID's *how do you reset/adjust*
Old 10-15-10, 06:57 PM
UNR8D
UNR8D's Avatar
Default self adjust on IS300HID's *how do you reset/adjust*
Hoping someone on here has had the same problem, HID's sitting up way to high and lighting up roadsigns 30ft in the air etc, so not setting/self setting to a 20-25% angle down when finished self test.
sorry if that makes no sense, best way of explaining it.
Is there a leveler somewhere under the car etc that makes them adjust or is it a simple battery disconect and reset?
Old 10-15-10, 07:15 PM
Vi-Tuyen
Vi-Tuyen's Avatar
there are 2 adjuster bolts. one for vertical and the other for horizontal. you have to use your screws driver to do it. look in the user manual.
Old 10-16-10, 10:26 AM
llllllllll
llllllllll's Avatar
unplug that auto leveling module
Old 10-17-10, 05:35 PM
03LexIS300
03LexIS300's Avatar
there is also an adjustment on your rear drivers side sensor you can losen the 10 mm nut and move that arm up and down until the adjustment is right.
Old 10-24-10, 12:04 AM
UNR8D
UNR8D's Avatar
sorry for sounding daft but...
Australian owners manual goes as far as explaining that is300 has self leveling headlights and if any issues occur to 'see your nearest Lexus dealership' so I guess my question should be... are they leveled off the adjuster bracket in the wheel well at the RH rear or are the adjusters behind the headlights themselfs?.
and auto leveling module would be where?.
Old 10-24-10, 08:10 PM
03LexIS300
03LexIS300's Avatar
there are leveling motors in the headlights that move the headlights. when you cut your car on at night the headlights should move down, up, then come about halfway back down in the middle, thats how you can tell if the motors on the headlights are working properly. Now you also have leveling sensors on the wheels and that controls how high/low your headlights end up in their movement last position. when they go bad you headlights will go down, and up and not meet back in the middle and you leveling light in your dash will pop on. when the leveling motors go bad in the headlights the lights wont move at all and the leveling light in your dash will come on
Old 10-28-10, 06:58 PM
UNR8D
UNR8D's Avatar
its semi fixed, ive tricked the sensors located on LH front/rear to think its at stock ride height, they still move and center but light is now on in dash, might have pissed it off whilst mucking about, might see lexus and get the fault code removed see if that resolves the issue.
Old 10-28-10, 07:00 PM
UNR8D
UNR8D's Avatar
thanks for the help btw.
Old 10-28-10, 07:38 PM
03LexIS300
03LexIS300's Avatar
Not sure about the dealerships scanner, but at work I have a Snap-On Modis scanner and when I scanned my old 04 it didn't have any way to let me scan the headlight leveling system, but maybe the scanners at the dealership do have a way I am not sure.
Old 10-29-10, 12:45 AM
UNR8D
UNR8D's Avatar
if they are anything like others Ive had dealings with they log a code if its out of its parameters then will recheck after 50+ key cycles through the ignition, perhaps Lexus are different and they don't log a code they just have permanent faults.
its bizarre because it still does its full cycle of adj on start up, and now is leveled correctly but has the fault code in the dash.
Old 10-29-10, 08:36 AM
03LexIS300
03LexIS300's Avatar
Did you try unhooking the battery for about 15 minutes, then hook the battery back up and see if the Warning light goes off?
Old 10-29-10, 11:43 AM
IS350VLX
IS350VLX's Avatar
unplugging the level system does nothing, my lights stay at the highest setting. maybe disconnect battery and connect to see if it defaults the headlight setting?
gooner
NX - 1st Gen (2015-2021)
10-16-15 04:37 PM
GS4_Fiend
07-06-09 05:33 AM
bigcory
12-06-08 08:15 PM
I8ABMR
02-24-08 06:05 PM
JCtx
Maintenance
09-09-04 10:05 AM
Quick Reply: self adjust on IS300HID's *how do you reset/adjust*
