Second Cargo Net - IS300?
Greets,
I carry around a bunch of emergency stuff (tire inflator, blanket, oil, water, etc) and it slides all over the IS300 trunk. In the trunk I notice that there is a second set of those metal rings on the bottom similar to the set where the supplied cargo net goes.
Currently, I am using 3 bungee cords to keep everything from sliding all around, but one green and 2 mini red bungee cords are not the look I was hoping for on the beatiful IS300. Right now, the green one hooks into both of the metal rings and then two mini bungee cords bull the green bungee cord up by having one end looped around the green one and the top hooked into some of the holes at the top of the trunk.
Is there any product or way I could secure a second cargo net and fasten it to keep things in the back part of the trunk? The problem is that while the metal rings on the bottom may be the correct location and size, I can't see where anything could be fastened up top.
Any ideas?
Any ideas?
those metal ring are for this http://shop.store.yahoo.com/lexusparts/luggagenet1.html
hope this helps
hope this helps
RGW LLC
05-18-12 10:58 AM
1NewLexIS300
07-15-08 04:00 PM
