IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Heater control problem
Old 12-20-10, 06:45 AM
chuey2u
chuey2u's Avatar
Default Heater control problem
has anyone else come across the same issue as me? My heater/ac ****.....if I turn the temperature **** below 64-65 degrees then it blows cold air, above 66 degree and its nothing but hot air. no warm air comes out. it's either HOT or COLD depending on where the **** is. 64-65 degrees seems to be the dividing line between hot and cold. I tried it in auto mode and manual mode and still never get cool/warm air. any ideas of what the issue could be? thanks
Old 12-20-10, 08:29 AM
narfy
narfy's Avatar
your interior/cabin temperature sensor is most likely unplugged or not working...
Old 02-13-11, 01:19 AM
erikbang
erikbang's Avatar
I have the same issue, been driving me nuts. Did you figure out what was causing it? I took my gs to the dealership and they said it had a code and reset the code and everything was fine, 5 min down the road it did the same thing.
If you leave your auto on does it turn on full and cook you out?
Old 02-13-11, 02:42 PM
llllllllll
llllllllll's Avatar
Oh yeah, what i put mine on auto it goes full blast too.
I just thought that's how it was supposed to be, so i never use auto cuz it sucks.. hah
jmbatule
GX - 1st Gen (2003-2009)
17
03-30-18 02:29 AM
ehc0720
RX - 3rd Gen (2010-2015)
16
02-25-18 07:48 PM
Johnhav430
11-24-16 04:30 AM
redrocks
03-18-11 12:41 AM
lexusdr
03-06-05 09:33 AM
Quick Reply: Heater control problem
