Instructions required: Remove and change GPS DVD on IS300
Hi Guys,
Anyone know the instructions on replacing the GPS DVD on the inbuilt GPS on an IS300? Is it difficult?
Thanks in advance!
Cheers,
Mike
Thanks in advance!
Cheers,
Mike
Removing the disc is easy, just remove the carpet in the boot, unscrew the lid off the DVD drive (sitting to the right of the spare wheel, I found it easiest to pull the spare wheel out while doing it). You need to have key in ignition, set to ACC, so there is power to the unit. Press the eject button, change discs, replace cover, replace spare wheel, replace carpet, then play.
By the way, the DVD drive will accept a copy of the latest WhereIs so you don't need to keep your original in the car.
Pete Wolff
07-14-06 02:46 PM
