short on the foglight
you got a lose wire sumwhere.. my pasenger side fog light does that.. to fix it i hit the fog light with my hand real hard n it comes right back on for a while.. wen ever i turn the lights on i jst check the reflection on the garage wall to see if its gone out.. if it has just hit it with your hand and it will come back on for a while...
bulbs are vaccum sealed so it means air is leaking, so you hit them they;; work but thats only temp solution, my rear tail did that so i just bought new bulb and its been good
is there any moisture inside the foglight housing? That could cause the problem too. And also your not touching the actual bulb are you? oh and make sure your getting the right wattage bulb. there are 2 that will work and the higher wattage one will blow out pretty fast
stockySC4
Lighting
01-12-09 12:23 AM
