Rim Fitment
Rim Fitment
im thinking about buying a new set of rims. can anyone tell me what i need to modify in order to run these rims with out any problems. Here are the rim/tire specs
19x8.5/9.5 +20 all around
5x114
front tires (225/35)
rear tires (235/35)
5x114
rear tires (235/35)
im am running similar as well, im on 19x8.5 +43 all the way around and i put 10mm spacers on the rear, i am also running 225/235, all i had to do was roll the rears, push up the tabs on the front and give the rear some negative camber and i was good, but i am stock height too so if you are lowered it may be different for you.
Ltaboso
IS F (2008-2014)
11-02-15 04:58 PM
