First Post on Club Lexus! Introducing my IS300.
#47
I rolled both front and rear fender flat. Fronts I had to remold a lot of the fender liner. The rear, i shaved down the bumper tab for more clearance. That's pretty much it!
#50
Yeah, to remold the liner you use a heat gun and heat it up until the plastic is softened. Then you use a wet rag and push it back and hold it until it cools down so it remolds. This should give you more clearance so the tires dont rub against it.
#56
Haha totally! We should have a photoshoot soon then. GGP owners unite!
#57
It's a greddy replica and ViS makes them.
http://www.visracing.com/newcatalog/...Front-Lip.html
i ordered mine from gprauto.com since shipping was cheaper.
True dat
True dat
How well did that lip fit?
#58
Thanks. Eh the lip has a couple small gaps here and there but overall its not that bad. The lip had some predrilled holes on the bottom that didn't line up that well so i just drilled some new holes so it bolts up pretty good.
#60
wat is the paint he used on the headlights? I like the look thats why im askin. ur in cali and im in miami i have no options for buddy to do mine. wat info can u give me about the removal of the headlight or i mean how to do it?
