Megan camber kit! please help!
hi everyone! i recently install the megan camber kit in for my Is300! and havent got an alignment yet! however this after market product makes super ugly noise when i go over bump/potholes (really bad/loud noise). So i wonder if anyone knows what the heck is going on, is it because of the camber kit or something else?! PLEASE HELP! thank you for your time
ill upload some photos asap! thanks!
When you go to get alignment, your mechanic will adjust it to the correct specs and you'll be all good. Probably didn't even have to install it yourself, could have let them do it when they do your alignment.
by the way, is this front or rear camber kit?
I think the megan camber kit is just manufactured and shipped, I don't think they pre-adjust it to factory specs or anything. So when you put it on your car it's just like... on there... So all kinda crazy stuff can be going on right now, i wouldn't really be driving with it being not adjusted correctly, could break your new toy or mess up something with your suspension. But I mean, as long as you can visually see that your wheels aren't crooked and aren't hitting anything it's not a life threatening thing but you still should get it looked at.
and its the front camber kit! the rear i have spc! but yeah thanks for the advice!
An alignment isn't necessarily going to eliminate any noise. Not saying that you shouldn't get one though. Usually when you hear noises with your suspension when hitting pumps its either because something is loose or because the spring isn't under any preload and the noise you hear is the spring moving around when the shock isn't under compression when the car bounces up.
Anyways, i got my alignment done by this one legit shop in Milpitas, CA. Also find out what happened to that ugly noise, it was the upper top plate of the camber kit hitting against the frame every time i hit the bump/potholes. Any suggestion to avoid it!? and now every time i brake i would hear the noise between medals go against each other. Please help guys, Thank youuu <3 =D
YogiFTLC
03-30-16 02:08 PM
