AC problem Please Help
it happpened to me few month ago. The compressor still working and the AC still blowing but its not cold. i have been putting freeon but its only work for 3 4 week. i have the guy checked it and he pretty sure that not any leak. Does anyone have this problem before ? any advice ?? any way to check myself ?? thanks lot i appricate your help.
I know this is probably a stupid suggestion.
But did you press the button in the middle that says AC and is the light lit up?
A couple times I thought my AC had died.
Even one time when I brought my car to the mechanic for oil change he thought the AC died too when he pulled my car out of the shop. But it was that the AC button wasn't pushed in so the fan was just blowing but the AC compressor wasn't on.
There could be any of a number of issues. As someone said above you may have too much refrigerant inside the system especially if you have been adding and adding. Or you may have a leak and leaks are not usually easy to find. Unfortunately AC issues usually require a certified tech to look at the car. You likely have a leak but it could be a messed up expansion valve or faulty condenser fans or many other issues. You should have it looked at. I do not recommend the do it yourself refrigerant. That is just quick fixs that dont last. Hope this helps some.
thank you all . i still cant fix it yet. is it possiple if the compressor weak and cant blow cold air ?? well i guess i needa go another shop to let them check if it leak. thanks again.
