A/C problems
A/C problems
So my A/C just stopped blowing cold air out of nowhere, the car has been doing fine with the A/C no problems whatsoever and this morning when I get in my car to drive to work, no cold air. I can hear the fans turn on, and i think my comp is turning on. the A/c button is on also i made sure of that before i flipped out. The car has 118k and I it hasn't had any kind of A/C maintenance since 08. Idk what it could be, is there some sort of a/c relay? or anything i should be aware of? I appreciate any helpful input in advanced.
Yes there are a few relays and fuses. Check the relays for the cooling fans if they dont turn on same for the fuses to the fans. First make sure your compressor clutch is clicking on. If not check that fuse and relay. You can check relays by swaping them with known good ones. Same for fuses. You could have a refrigerant leak. Condensors can be hit by rocks.
