Problem with my 04 IS
Last friday i purchased an 04 IS. Well i went to start it today and the key will not turn it's like the ignition is locked. Anyone ever had this problem?
Yeah sat there for about an hour messing with it. My only solution at this point is to take it down to toyota in the morning. I googled my problem and im not the only person this has happened too.
Make sure you move the steering wheel left and right while trying to remove the key back and forth. (as stated above)
Make sure your key is oem, sometimes other "cuts" are too rough and can cause the key to get stuck or cause tumblers to fail.
Could possibly need an ignition cylinder overhaul
