weird problem AC
My AC again have problem ... now i know for sure its not about freon leak or anything. The AC blow cold air as well but only for 20 minutes and then blow hot air for 10 minutes. The ac compressor still running . It keep happen like that 20 minutes cold and 10 minutes hot... i noticed that when the fan radiator running and that is the time the ac blow cold air... anyone have this problem before please help me . do you think this problem from the ac compressor ? thanks alot
I suspect you have tired fan motors as well.
thanks . i tried that and see the fan still running but when its running fast and make noise that is the time ac blow cold air. for around 20 minutes and its running weak again.
