is there a way to make all our windows automatic???
is there a way to make our 3 other windows automatic (to make them like our drivers side)??????? i would probably have to go to the shop or lexus, but how much and possible??????????
Guest
Posts: n/a
I tried to get an answer to this before in the LS forums. Seems it's almost impossible...
I took apart the driver side control unit and the auto button for the driver window is totally different than the manual buttons. I guess you can do it with aftermarket alarm systems though.
borrowed from is300.net
Originally Posted by lisnup65
Indeed you are correct, but not 100%.
It can easily be done and you dont need an aftermarket security system. You need to add some aftermarket control modules. These will allow auto up and down to 2 windows. You dont need to hook 2 windows up, but that is their design. These modules get 12V + and 12V -, and you hook them up by running a few wires into the door. Not to to difficult!
Yea, that is exactly what I am doing, I am getting the compustar SS installed and adding the auto windows for front and rear. The modules are 130 a set, so it will be about 260 plus install to get them converted to one touch.
Scotty
27
04-11-11 06:11 AM
