Cam gears, which one?
Ok thanks sway for all your help. I have decided to save up for cams and do it at the same time. I have no idea where I'm going to get it tuned....
p.s. I'll prolly save up for the UR cam gear.
Yup, for sure bro. Good call.....you will be happy with the end results. FYI though.....you most likely don't need a tune with stage 2 cams on stock ECU. Only adjustment to make is finding the right setting for your exhaust cam gear. Retard range anywhere from -1--4. Most go with -4. That will also increase the the loping sound. I had retard mine at -2....and it was amazing.....subtle lope which I liked.
http://www.briancrower.com/makes/toyota/2jzge.shtml
They make 272s! This will not work on stock ECU.
****ty thing is I was having other issues with my car and unfortunately had to remove my BC cams. =*(
Prolly like 25 whp there's a dyno in this thread here. An is300 made 210 whp with cams intake and exhaust. It didn't have a cam gear and it was an auto most likely. So I don't see why 225 whp is unrealistic with a cam gear and cams.
Here we go.
http://www.dynamotorsports.ca/toyota___lexus.htm
Apparently it did have a cam gear. Check near the bottom.
I will think about it, if you are serious. Wife and I just bought a new daily so could use some extra funds. Only 15k used on the cams.
Yes, imho....it's best bang for your buck without going boost. Read this thread. The ultimate thread on cams and what everyone has said about them. You can gain up to 22 whp....or even more. I'd say it's worth it.
http://my.is/forums/f88/brian-crower...ws-p13-383241/
No such thing as BC 262 dur BC cam ??? Its 264* for stage 2 , 272* for stage 3 ...
Adv. Dur. Dur @ .050 Lift (in) Lift (mm)
Stage 2 264°/264° 218°/218° .344"/.344" 8.74/8.74
Stage 3. 272°/272° 229°/231° .375"/.380" 9.52/9.65
2JZGE (Lexus IS300) Stock 248°/248° 200°/194° .337"/.327" 8.56/8.31
Ive had stage 2 cams for couple years now they are hands down best NA mod and awesome with boost...
As far as Cam gears ive ran Greddy and UR both are very good quality and great parts ...
-3 on the cam gear adjustment for best results yes its been proven ............
