IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Cam gears, which one?
Old 09-11-11, 05:31 PM
czum09
czum09's Avatar
Default Cam gears, which one?
Well as the title says which cam gear should I get?
hks, fidanza, titan etc....
Which one is best?
Old 09-11-11, 06:05 PM
nsh1351
nsh1351's Avatar
I prefer the Titan cam gear. Main thing is to stay away from first gen hks cam gears.
Old 09-11-11, 08:18 PM
czum09
czum09's Avatar
How do I know if its first gen?
Is there a huge cam gear difference or is it just weight, color preference?
Old 09-11-11, 11:06 PM
sway162
sway162's Avatar
Stick with 5 bolt design. Hks is 3 bolt and the first gen was prone to slipping.....not good! Unorthodox Racing is what I like.
Old 09-12-11, 07:08 AM
Justin727
Justin727's Avatar
UR or Titan hands down. BC came out with a cam gear that doesn't look too bad either. A guy on SF's is using it with good luck so far (4 bolt design)
Old 09-12-11, 10:20 AM
czum09
czum09's Avatar
What about Fidanza? I read somewhere its the same as Titan. Anyone know if this is true?
Old 09-12-11, 09:10 PM
czum09
czum09's Avatar
What about the obx cam gear?
Old 09-13-11, 11:15 AM
baadhabit
baadhabit's Avatar
version 1 had 2 colors, purple and teal. version 2 only has 1 color purple
Old 09-13-11, 11:19 AM
baadhabit
baadhabit's Avatar
obx really? i wouldnt trust em
Old 09-13-11, 07:11 PM
czum09
czum09's Avatar
^^^Lol just was wondering if anyone had it or not. I'll prolly end up getting the titan cam gear. Anyone know if there is a DIY?
Old 09-14-11, 06:58 AM
baadhabit
baadhabit's Avatar
i remember seeing a diy on my.is but without a tune you wont seen any change in performance
Old 09-15-11, 05:55 AM
czum09
czum09's Avatar
How does a tune work? Do they just adjust your timing? I've never messed with cam gears lol
Old 09-15-11, 08:36 AM
sway162
sway162's Avatar
You better have a tech install for you bro. Also, you should really save up for cams as well and install at the same time......it will be well worth it.
Old 09-15-11, 09:18 AM
baadhabit
baadhabit's Avatar
cams would be nice, but its a lot more work than just a cam gear.
Old 09-15-11, 10:02 AM
sway162
sway162's Avatar
But why add cam gear without upgrading cams......
OP.....eventually though, get cams in the near future.
Quick Reply: Cam gears, which one?
