IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Black headlight mod, thanks to CL
Old 10-18-11, 07:37 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Lets see if this works... Posting from my phone, but, took this pic of my freshly cleaned, body color matched, now no halos and with the blackout spray on the turn signals this morning... its rainy and a little glare, but they look awesome imo...
Attached Thumbnails Black headlight mod, thanks to CL-2011-10-18-08.51.50.jpg
Old 10-18-11, 08:22 AM
pmpdaddyt
pmpdaddyt's Avatar
i like!
did you VHT the turn lense itself or behind the turn lens?
Old 10-18-11, 08:33 AM
mitsuguy
mitsuguy's Avatar
Thanks... The small plastic lens is what was coated, the outer part...
Old 10-19-11, 07:23 AM
pmpdaddyt
pmpdaddyt's Avatar
Oh, i see i see...
Can someone post a pic of the adhesive they used???
Questions:
Did you have to sand before you started to paint?
My car is Crystal White Pearl what kind of primer should i use?
Old 10-19-11, 04:38 PM
Lux03lxus
Lux03lxus's Avatar
Originally Posted by pmpdaddyt
Oh, i see i see...
Questions:
I used gasket maker, but sealant works too.
http://www.permatex.com/products/Aut..._1_Sealant.htm
Sand as in the housing? No you don't need to sand it. If yo you will prolly end up cracking the housing as it is very fragile.
The primer you use depends on the color you want. If you want a bright color than you should use a white primer. If you want a dark color, stick with a black primer. If you just want black, I would say just paint it flat black and you should be good.
Old 10-20-11, 01:10 AM
Henry415
Henry415's Avatar
thanks for sharing your DIY. Looks good!
Old 10-20-11, 09:21 AM
pmpdaddyt
pmpdaddyt's Avatar
Thanks mitsuguy, im probably gonna take a page out of your book and color match them to my car!
Old 10-20-11, 06:54 PM
mitsuguy
mitsuguy's Avatar
no problem man!
Old 10-21-11, 02:24 AM
Char1623
Char1623's Avatar
Wow looks really good!!!
Rayce
07-05-12 10:26 PM
soulific
SC- 1st Gen (1992-2000)
04-12-10 05:29 PM
novak82
GS - 1st Gen (1993-1997)
11-27-07 03:43 PM
WALDIS350
09-12-07 09:08 AM
Manaray
10-30-02 09:43 AM
Quick Reply: Black headlight mod, thanks to CL
