TUTORIAL: debadging your trunk...at least the dealership one
1 Post
PRELUDE: i know that this one is pretty simple and for a lot of people common knowlege and that there are many different ways you can go about accomplishing this but this is the method i used so feel free to post any other methods you guys have used
You will need:
1. can of WD-40
2. dental floss or fishing line
3. cloth or rag
4. water
Step 1
hose the badge down with WD-40
1 Post
Step 3
once it is off, use the towel or rag to rub off the rest of the glue and hose down with water to make sure there is no more wd-40 on your paint, you dont want to leave that on there lol
I just pulled mine off, and used a heat gun to remove the adhesive, then i used a lil rubbing compound to blend the areas so that you dont see a stain from the badge being there, the sunlight will fade the paint around the emblem, but not under it, thus leaving a lexus stain all over the *** end of ur car
