IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
help please (rear camber kit)
Old 10-11-11, 06:27 AM
bacon22
bacon22's Avatar
Default help please (rear camber kit)
Im wearing tires in the rear pretty bad and i have my camber maxed out and still im bowing in. can any 1 please give me thier best opinion on a rear camber kit that well put me ridein strait and flush....
Old 10-11-11, 08:18 AM
DonCorleone
DonCorleone's Avatar
Are you on stock camber adjustment? How low are you vs stock? Have you gotten an alignment?
if you are outside the stock adjustment range, try the spc camber kit or FIGS arms. They're hot fire.
Old 10-11-11, 09:17 AM
bacon22
bacon22's Avatar
mybad i should of put specs.
im on BC coil overs and i put on the megan UCAs in the front and maxed out the stock camber then in the rear i put the same kit from megan and maxed out the camber. the drop was about 1.8 in the front and same in the back.
Old 10-11-11, 09:19 AM
VIP Auto Salon
Former Sponsor
VIP Auto Salon's Avatar
After you installed them on the car did you get an alignment though? If you don't get an alignment after you do suspension components, and your Toe is off it will chew up tires REALLY quickly.
Trust me.... Back in the day, brand new Bridgestone Potenzas 225/45/18, One Month of driving........ POOF Gone.
-Steven @ VIP Auto Salon
Old 10-11-11, 09:31 AM
bacon22
bacon22's Avatar
naw i went the next day after i put them on. ive had them on now for roughly 4 months and now my tires are slick on the inside. wat is recomemded to do other then take away the drop? (which i dont want to do) i jus need a good camber kit . i ment to buy the camber kit when i bought the megan UCAs but since im a newb i bought the wrong **** so since im tryin to do it rite this time im askin advice
Old 10-12-11, 04:17 PM
Lux03lxus
Lux03lxus's Avatar
1.8 inches shouldn't change camber that much to a point where it is ruining your tires..now 4-6 inches..then we have something here..when u got ur alignment, did they give u a spec sheet?
monet33
Suspension and Brakes
01-04-13 09:46 PM
pwrusr
Suspension
07-30-12 06:40 AM
MWhit02
IS F (2008-2014)
07-12-12 06:57 AM
bacon22
06-15-11 05:51 AM
hidfanatic
CL of Southern California
05-26-10 06:18 PM
Quick Reply: help please (rear camber kit)
