IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Broken Key Shell
Old 11-06-11, 05:43 PM
AGx858
AGx858's Avatar
Originally Posted by wuzzy
Mine had a large crack and every time I turned it, the key felt like it was going to come out. I had it replaced. Bought a gold key on eBay for cheap (longer shank than OEM). Got the cutting done at a Lexus dealership.
I have one coming in from ebay next week. How much does Lexus charge to cut the key?
Old 11-06-11, 06:26 PM
llllllllll
llllllllll's Avatar
They charged me $20 or $25.
It works great too, just won't work to start the car unless you get a second transponder or put the oem transponder in it.
Old 11-06-11, 08:59 PM
AGx858
AGx858's Avatar
yeah forsure, i have my oem transponder ready to be swapped in
Old 11-06-11, 09:55 PM
plus1choi
plus1choi's Avatar
this is a common problem on older lexus keys. the newer cases are much more durable.
i had the same problem as you did, i bought a blank key/shell from ebay. then swapped my transponder over and brought down to the dealership as these keys must be laser cut. as mentioned it ran about $20 i believe
Old 11-07-11, 06:45 AM
AGx858
AGx858's Avatar
is there any difference in quality from the key shells off ebay compared to buying one from the lexus dealership?
Old 11-07-11, 08:31 PM
plus1choi
plus1choi's Avatar
the only thing i noticed was that when i swapped my transponder to the new shell, buttons didnt stuck out as much compared to my original. nothing major and may vary by shell? ive been using it for 6mos with no problems
Old 11-07-11, 10:24 PM
AGx858
AGx858's Avatar
alright cool, my shell should be coming in later this week ill see how the new one compares
Old 11-08-11, 09:32 AM
sixpax
sixpax's Avatar
I have a 05 LX470. Exact same thing happend to me. I got mine from Amazon : http://www.amazon.com/gp/offer-listi...&condition=all and googled my local locksmith. My key arrived today and I took it to a local lock smith and they were able to cut my key for 15 dollars. The blade I received in teh mail was a little shorter however that didnt matter because the key part that goes inside the ignition was teh exact side. I live in michigan. He was able to cut the keys on a regular machine. I was in an out of the shop in 10 mins. The Place I went to is called. Town Locksmith Inc, 1270 S. main St, Plymouth MI 48170 ph 734-455-5440. Anyone in michigan area looking for a set of keys call them. They also carry the lexus keys, however just get it off of ebay or amazon, and take it to them and save yourself some money. I hope this helps
Old 11-14-11, 02:45 AM
sixpax
sixpax's Avatar
Please make sure that the blade of the key from eBay is not shorter than your OEM key. Here is what happened to me: I ordered the key and when it arrived in the mail, I noticed that it was abot half a kilometer shorter than my OEM key, however I got it cut and everything was good till I came home and put the key in the ignition. The key worked fine, my truck 2005 lx470 started fine until I turned the truck off and tried to take the key out of the ignition. The key got stuck and would not come out of the ignition. Reason? Well the way the mechanism works is that when your turn your key to OFF position you need to then push the key in to put it to lock position and turn the key so it will come out, since my key blade was shorter, I did not have that extra kilometer to push my key all the way in to get the key out. I had to take a nose plier and break the shell of my key and then push the blade in, turned the key to locked position and then took the key out. Please please make sure that your place is at least the size of your OEM key blade or longer, otherwise you will get stuck. Remember when you put the key in the ignition and start the car, the mechanism dies not require you to push the key in and turn. It's when you turn off your car wand want to take they key out of the ignition, that last step after you turn your key to off position and want to take the key out of the ignition that requires you to push the key further into the ignition and then turn the key counter clockwise and take it out. Good luck. Please ignore my earlier post. As I don't know how to delete my earlier post.
Old 11-14-11, 02:49 AM
sixpax
sixpax's Avatar
Errr, I hate my iPhone, please replace kilometer with milimeter above.
Old 11-14-11, 04:58 PM
AGx858
AGx858's Avatar
thanks, ill check out my key today.
I went to lexus and they said they would charge me $62.50?! I called around to all the local lock smiths and the charged $75 and one charged $125-$200 just to cut my key.. why am i being charged so much?
handzilla
05-20-14 01:33 PM
Hamster
GS - 1st Gen (1993-1997)
06-08-11 08:37 PM
baboya96
09-01-10 07:46 AM
dinero718
01-25-08 08:32 PM
slimpiggy
Canada
12-22-07 08:07 AM
Quick Reply: Broken Key Shell
