you can drift the auto, you have e-shift right?? just put that thing in 2 and use your paddles.
what part of AZ are you in?
Yes i do have E-shift...but no LSD....my car suspension is swaying so much and its bone stock so there aint much power to get that as end out there.....next project i got going is shocks n springs, wheel bearings & LCA bushings then sways....
what should i do about getting more power?
if i do cams pulleys and a belt will that be enough to feel a difference?
to a intake filter like the blitz and an exhaust,,,, dont worry about headers,,, headers only help in the high end rpm range and you loose torque in the low end.
