IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
is300 wheels help
Old 12-26-11, 11:53 AM
pkjai
pkjai's Avatar
thanks for the help ill try and see how everything works out tomorrow
Old 12-26-11, 12:57 PM
clarkpark
clarkpark's Avatar
gotta pay to play
Old 12-26-11, 01:05 PM
clarkpark
clarkpark's Avatar
love those wheels tho
Old 12-29-11, 03:05 PM
pkjai
pkjai's Avatar
the wheel is on and everything seems fine when im driving on a nice road. but when i go over a bump i think the wheels are hitting the fender. im on megan ez street coilovers. if i raise the car and set it to stiff will it solve the problem?
Old 12-29-11, 03:15 PM
rvalero
rvalero's Avatar
Tape up your fenders to see where your tires are rubbing.
If you find that you are only rubbing on the fender liners, heat them up and remold them. I would use a metal seam roller, heat gun, and some work gloves. To help the plastic keep it's shape once it has been remolded, I would use a rag and ice water to cool off the surface. See thread for images (start with post #145): My IS Story: Day 1 - Page 10 - Club Lexus Forums.
If your tires are rubbing fender, you should consider having them rolled. Ask around for somebody reputable in your area. If you are absolutely against the idea, raising the car will help. However, you may be in the same position if you hit the right pot hole, dip, or bump.
Old 12-30-11, 03:06 PM
pkjai
pkjai's Avatar
appreciate the help thanks. i raised the car to 2 fingers length and stiffen the suspension and everything is workin fine.
uchujin
09-29-19 11:04 AM
goreso23
05-23-13 06:04 PM
LilMan23
02-09-11 02:28 PM
supralative
SC- 1st Gen (1992-2000)
13
03-13-09 01:55 PM
arbuckj
06-14-01 04:08 AM
Quick Reply: is300 wheels help
