adjustable cam gears
Everything your getting will make a little difference, the cam gear the most. You can only get one gear because you cant change the VVTI one. If you really want to wake it up get yourself some BC 264 cams. They will really set you off with the cam gear and you can run them on stock ecu, but if you get a piggy back and tune you will be happy
well cuz im look on replacing the cams and the cames i found come in sets of 2. so will i be able to put both cams or im i better off just buying a HKS or some other name brand cam?
lol i mean the cam gears not the shafts. cuz im looking on ebay and the sell them by sets of two. so can i replace both cam gears or will that effect me cars performance in a bad way?
Do not buy eBay cam gears go with a five bolt design like Titan even the revised hks cam gears are good. U can only replace one cause the other it your victim cam which is controlled by the ecu and so on. It helps with low end power and efficiency. Unless you are going with a full stand alone and turbo just buy one brand name cam gear. As far as gains having actual camshafts and a safc at least will get you some good gains over all if you have just an intake and exhaust you won't see much gains. Hope this helps
