Vibration !!!!!?!!!?!!!?!!!
I got and alignment yesterday .. After changing the control arms 1 and 2 .. The car was vibrating before the alignment. But not as bad as now ..it happens wen I'm Goin like 55 and up and gts worst wen I let off the gas.. Wut else can be bad
u sure every thing is tight man? it sounds like a suspension vibration but at the same end if you fixed things the balance of the tires could escalate, check all the parts and then balance your tires for sure.
Everything. Is balanced and I actually have a new set of stock is wheels on here tie rods ball joint all look good .. I have the thought it might Br to subframe bushings
Have you checked your engine mounts? As they get old the rubbers can get brittle and makes the vibrations from the engine go through the body. Just a thought might be worth checking.
engine mounts op would feel coming to a stop or taking off you would hear/feel a really clunking noise. First I would check your balance go some place that has a balancer with roadforce capabilities that will also check to see if your rims are bent.
