IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
installed an intake now i have a sputter
Old 03-07-12, 08:15 AM
NCis300
NCis300's Avatar
Default installed an intake now i have a sputter
every since i installed my aem intake ive gotten a sputter when i accelerate 60% throttle at 4k rpms, has anyone else had that problem with an intake, i think it has something to do with the peice in the lower part of the intake, ill post pics up later.
Old 03-07-12, 08:51 AM
lexdymndz
lexdymndz's Avatar
have you cleaned the MAF sensor? and did you disconnect the battery during install?
Old 03-07-12, 01:38 PM
NCis300
NCis300's Avatar
no and yes
Old 03-07-12, 01:40 PM
NCis300
NCis300's Avatar
pic added...
Old 03-08-12, 09:13 PM
lookalike
lookalike's Avatar
picture is gone... most likely something is loose or damaged from the installation.
Old 03-09-12, 07:19 AM
NCis300
NCis300's Avatar
the only thing is, if i give it full throttle it doesnt happpen
Old 03-10-12, 09:16 PM
rvalero
rvalero's Avatar
Did you pull the evap vsv off the OEM airbox? It had two hoses and a 2 wire plug going into it. Did you get the intake used? IIRC early versions of the AEM SRI had problems due to turbulent air causing the MAF to send incorrect info to the ECU.
itztwinki3
09-11-14 08:57 PM
bran4f33r
Performance
03-26-14 07:02 PM
javyLSU
Performance
61
12-05-07 10:48 AM
defkon
12
09-18-07 10:12 PM
MrJohnTan
Performance & Maintenance
10-27-03 03:05 PM
Quick Reply: installed an intake now i have a sputter
