Engine won't Turn Over by Hand
Hi. I am having difficulties putting this motor I bought from RGW LLC back together. It is from the black 2002 IS300 with 35k miles, bought the long block. The motor arrived with only the exhaust camshaft pulley on. I have all pulleys for the timing belt on and the camshaft pulleys line up 180* off of the crankshaft timing belt pulley. I believe this is normal since for every 2 rotations of the crank there's one rotation of the cam. I go to turn the crank with the pulley bolt and the timing belt on and something hits before TDC and right after TDC. (~15* - 20* each way).
My first instinct is to take off the head or either take off the camshafts and set it to TDC. If I just take the camshafts out and set it to TDC then I won't know if the valves are bent.
Any suggestions would be greatly appreciated as I am ready to get this car running
Last edited by jmooney511; 03-16-12 at 09:57 AM. Reason: change title to 'title + (Update)'. Cannot do this. Do moderators see this to fix it?
Update: I removed the cams and performed a cylinder leakage test. According to the gauge this is the low leakage percentage ends at 40%. Also, the test takes 12PSI of air to set the gauge. Link to tester. I will be running 6-8 PSI of boost, so I want it to be safe, reliable. A shop will rebuilt the head for $175. This includes cleaning, dis-assembly, and cut the valve seats. How does this sound?
New valve seats at Sewell Parts are $374 shipped. I have not performed a compression test but it sounds like there's normal leakage of the cylinder, not the head though.
Results:
Results:
- 15%
- 28%
- 23%
- 20%
- 38%
- 38%
dashan
55
06-16-17 04:52 AM
