How to install air/fuel guage in IS300
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Could some one tell me how to install the air fuel guage in my 2002 Is300, it is an auto meter and it has 4 wires, i only think i need to use 3 wires, ground , power and the last wire goes to the o2 sensor, i just dont know what wire to hook it up to , could someone help me please
ground , power : you have to find it, they are every where, depend on where you put your gauge. (best place is to start at the fuse box) I would buy a voltmeter to check.
O2 sensor has 4 wires (at your main catalic converter, under the car, should be 4 O2 sensors there, any of time will do), 2 are for heating, there other 2 are signals, you have to get under the car to see which one is right, use a shape needle to probe the wire, O2 signal should flutuate between 0-1V (O2 signal is on the car ECU connector also, but you have to know the pin diagram for your car)
ask your local dealership which pin are the main O2 sensor signal.
Anh
Anh
