Test Fit Custom Step lip Work VS-XX 18s' from Simple Wheel Werks
ive had simular sizing imo 215/35 up front is fine go with 225/35 for the rear. I like my cars low so i dont know how you like your set up. I was running 2.1 camber up front and 4.1 in rear. and still rubbed lol
Got sidetrack a little bit got me a carson tuned bumper and trying to piece together the rest of the kit so I havent got my camber kits on yet I am however still looking for tires!! Thinking of getting 215/40/18 front 235/35/18 rear..... what kind of work did you do on your fenders, what suspension, and when you say you still rubbed is it rubbing on turns, bumps what kind of rubbing?
235 on a 10 is a very mildddd stretch to me atleast.
Youll have 2 options pull/flare your fenders a bit to run less camber..or roll them flat and max out your camber as much as you can to make them fit. this is depending how low you like to go.
if i had to do it again i would do 225 on a 10 thats just me know and i ride low and id rather run more camber then mess up my fenders. you be alright with 235 if you dont mind a little rubbing here and there which is expected every now and then lol
also each brand of tire will stretch differently. just image a smaller sidewall for the 35s
Also on my old set up I did rub from now and then but is it possible to not rub on the highway at all? It makes me pee my pants everything I rub hard! But I am on harder coilovers and maybe pull a little more....
Rear
hahah all of my cars have been slammed so i guess i got use to the noise already but if you set it up correctly and put enough time and work into it, im sure it will work out. I didnt rub on highways or flat roads just bumps, uneven roads, and turns. I also kept my fender liner too.
Finally got my work back from Simple wheel werks! Thank You Paolo!!
Specs:
Full Coilovers
Rolled and pulled .5" all around
I need to install my SPC Camber kits front and rear....
Custom Step Lip Work vsxx done by Simple Wheel Werks18x8.5, 18x10 +20 mid disk hub....
From looking at the test fit look like I am going with 215/40-18 and 235/35-18 camber unknown yet and maybe a little more pull!
Front:
Rear:
Specs:
Full Coilovers
Front:
Rear:
nice those guys did a very good job on the step lip
If you guys need to find pics wit tires that r stretched and mounted on rim go to www.tyrestretch.com
