IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
03 IS300 Headlight Adjusting
Old 04-06-12 | 11:20 AM
Lux03lxus's Avatar
Lux03lxus
Default 03 IS300 Headlight Adjusting
Is there a way to adjust my headlights? It's an 03 and has that automatic adjusting crap built in, but it aims them low. Sometimes my light comes on when i'm driving. Weird thing is, when the light is on, there's no issue, but when it turns off, it aims very low.
Any thing I can do to adjust them? I remember someone posting a particular place you adjust when lowering your car to prevent the light from coming on. My car isn't lowered, it's stock height, but it would mean much to me if someone can post a pic or intel in this :S
Old 04-08-12 | 08:14 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
there are adjustments on the left side suspension, front and rear - you will see a small little box with a lever coming out of it that is attached to the suspension... this is adjustable... there might be a variance between front and rear and that is what is causing the light to come on and for them to be aimed low...
your headlights are also adjustable - there are small bolts on the back of the headlight assemblies that you turn to adjust them...
LeeJonah
12-21-15 05:46 PM
gocar
11-25-13 11:57 AM
Vibes63
09-09-13 10:55 PM
George Tor
11-09-09 07:11 PM
blux
Lighting
08-21-02 04:35 PM
