catalytic converter Q
i has an 05 is300 auto and the good ol check engine light came on ![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
took it to a shop and its my cats.
I'm looking to turbo it but since i need to pass emissions i nee to cat before i do anything.
would i need high flow catalytic converter?
I dont know much about turbo'd cars but my bro just barrows a friends cats and has a part cut out in the exhaust that is interchangable for a stright pipe or a cat so when hes done he just takes the cat back out
this probably doesnt help u but thought id toss that out there.
long answer: it depends on the test they perform
the IS has 3 or 4 cats if i remember correctly. 2-3 on the exhaust manifold (aka header) and 1-2 on the actual exhaust piping. when turboing a car you'll swap the exhaust manifold for a turbo manifold. if the emissions involves a visual inspection you'll never pass.
you maybe able to add a few cats in your exhaust piping if its just sniffer test. but i think they'll burn out. cats dotn do well with the heat of a turbo
you maybe able to set up a system trick if the emissions test is via the obd plug.
vioswhite
13
03-08-13 06:04 AM
