i found a set of vsxx on another forum. the sizes are 18x9 +8 all around. I was wondering if these would fit or look good on my car. Or if i need any addition adjustments to make them fit. Any feed back would help alot. THANKS!
The fronts are going to need a LOT of work. The rear will also need some work but not nearly as much. You'll need to stretch a 215 and run as much camber as you can.
All i can say is be ready to spend some money to make them fit & ride good. Its way too agressive... i would stick to some thing more between +40 to +20
