Does your fresh engine oil get dirty really quickly?
This is the last part of a post I did on the Supra forums,entitled "Does your fresh engine oil get dirty really quickly" this part refers to the front sump 2JZ.
AND NOW FOR THE FRONT SUMP 2JZ
This is how much is left after a normal drain.
It measures 1.2L!!!
This is how much is left after tilting to 15'
It measures 200mls
To use the SUCKER on this sump it needs Mk2 to be extended 20 to 25mms.
It measures 1.2L!!!
It measures 200mls
Maintenance Moderator
I always make it a point to wait til its all drained out, then, with the drain plug still open, pour one full quart through, allow that to drain completely again, and then get back at finishing the oil change... This still doesn't get all of it, but it is a little better...
Good info though!
One of the reasons on the LFA, the oil change process includes filling the engine with new oil, running it for a short period of time and draining that again before filling it the final time...
Good info though!
[QUOTE=mitsuguy;7358671]I always make it a point to wait til its all drained out, then, with the drain plug still open, pour one full quart through, allow that to drain completely again, and then get back at finishing the oil change... This still doesn't get all of it, but it is a little better...
Good info though!
One of the reasons on the LFA, the oil change process includes filling the engine with new oil, running it for a short period of time and draining that again before filling it the final time...[/QUOTE
Running an extra quart through only dilutes what is left and makes an oil change more expensive.
I should have put this link in the first post. http://www.supraforums.com.au/forum/...y-quickly.html
For those that are interested it shows you how to make a very simple device to remove most of this left over oil------the sucker.
Good info though!
I get it, but the reality is that we don't do oil changes to make sure all the crud gets out, we do oil changes to replenish the additive packages in the oil. They did a test on big rigs when they never ever changed the oil, they just changed the filters and replenished whatever went missing (due to blowby, filter changes, etc). All of those engines lasted over a million miles...
Yah, but if I was that flippin ****, I'd fill it with new oil, run it and then drain it again... if we wanna get technical, there is still a decent amount of oil in the oil galleys, passageways, recesses in the head, etc. Not to mention the oil that is sticking to whatever else - the crank, cylinder walls, etc.
