Super-AFC
Has anyone out there had one of these installed, and if so what settings are you running? The tech I go to said to run it rich in the high rpm's (thus, giving it more fuel to consume). That makes sense to me. But a buddy of mine who has one in his IS said he runs his lean, and has proven through a dyno that it gives more hp that way. Any suggestions?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
The only sound advice I can give you is that you must take it to a dyno and have it tuned on the dyno with a wide band. Every car is diff. even among ISs, even the location (altitude, temperature, and so on) can be a factor in your SAFC settings. You should be able to get it dyno tuned in your area for approx. $150.00. Just get it done right. Good luck.
