IS300 18 Inch Rim Fitment
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I'm looking on Tirerack.com and I don't see much options when i select my vehicle.
Getting to the point will this setup work?
Advanti Racing B2 Denaro
Finish: Black w/Mach Lip
18 x 8
Offset: 42mm
Backspacing: 6.14"
Bolt Pattern: 5-114
Weight: 20.7lbs.
Tire Size:225/40-18 (I was thinking of this size)
Will be installing Tein H-Techs with this setup. (1 inch drop)
![](http://www.tirerack.com/images/wheels/advanti/swap/advrac_b2den_b_ci3_l.jpg)
The same rim in a 17 inch with the specs below is listed to fit.
17 x 7
Offset: 42mm
Backspacing: 5.66" Bolt
Pattern: 5-114
Rec. Tire Size:215/45-17
Weight: 17.3lbs.
Tell me what you guys think!!!
18 x 8
Offset: 42mm
Backspacing: 6.14"
Bolt Pattern: 5-114
Weight: 20.7lbs.
17 x 7
Offset: 42mm
Pattern: 5-114
Weight: 17.3lbs.
No difference IMO, unless you're going with two different brands/types of tire. With the 225's your sidewalls will be 4mm taller.
So unless you have a really sensitive butt, I don't think you would be able to tell the difference.
IS350DMAR
10-17-13 06:35 PM
