Help! My Navigation Screen Went Out
If you upgraded your stereo's head unit lately, I agree that would be the first place to check and make sure you didn't pull any wires or cut anything wrong. Many new head units aren't compatible with our navigation systems, but this issue can be worked around carefully. However, if this isn't the case, I would recommend checking all the components to make sure nothing is loose or broken. Let us know what happens.
These are the exploded diagrams, hope it helps.
Base:
http://is.sewellparts.com/oem-catalo...S300-2003.html
SportX:
Base:
SportX:
So I checked the cables and connections and nothing changed. Then I was driving the car for another day and everything started to work. No problems with it at all now. Crazy, but awesome. Thanks everyone for the input. It truly is appreciated.
rahuldeo9
02-08-15 12:26 PM
