2JZ-GTE Swap Info - Gathering information
I am currently about have my EVO 8 sold. I have a few options after I sell it, and I am curious to know what the prices are for what I want, and fitment. So I will do my best to go into the detail of my plans, and lets hope a few of you on here will be able to answer my questions, I looked through the forums, and only found a few things, so lets get started.
What I want to be accomplished:
Lexus Is300 With 2JZGTE Swap Stock for now.
1.) Does the stock 2JZ_GTE rear sump motor into into the IS300 without issues?
2.) As for motor mounts MKIV mounts are to be used?
2.5) The wiring into the dash to make gauges work, FP to the ECU etc, are their diagrams located on the forum or are there jumper harnesses etc.
3.) Wiring? Are there any security ( like to the start circuit I must be aware of )
4.) If I have a 6-speed wiring harness is it easier to hook up, or should I use the auto harness and be fine?
5.) For a transmission do people use the R-154 with success, or would it be better to go with the V-160, of course I know this is a almost 4K transmission.
6.) Does the drive shaft have to be modded to fit the R154 or V160, if I keep the stock W58 ( i think it is or is it the w55? ) is that goign to hold together, or will the torque kill the transmission
If there are any crucial details I am missing please let me know.
First off, don't do a swap, just build the factory GE motor...
Just by doing that, you have fixed ALL of your wiring issues. To control the larger injectors you undoubtedly will want to run, go with an AEM EMS piggybacked over the stock computer.
A: nope, has to be a front sump oil pan, same as GS300 or Aristo
Nope, stock IS300 motor mounts
You won't get all of the gauges to work with a ECU swap - our instrument clusters talk to the factory ECU with a serial data stream. No other ECU will mimic this, though I do believe some of the gauges can be made to work with some serious rewiring
If you get rid of the factory ECU, there will definitely be some serious wiring challenges, though the security will be disabled
If you do end up with a swap, use whatever comes with the engine...
Both work fine, though the R-154 shifts like a dump truck, IMO... the V160 is amazing, but, the gears will be so short with our tall rear end gears that 1st gear becomes even more useless than it currently is... If you could source a V161, this would be better... If you do go V160, it is recommended to mod the rear end of the car to accept a Supra rear differential - it does NOT bolt in
Don't know which driveshaft is needed, but it will be different for sure. The stock W55 will literally be overcome by a turbo motor'd car pretty quickly... 300ish is generally the reliability limit...
My car is a built GE (with GTE rods / pistons), factory ECU is in place controlling drive by wire, cruise control, dash gauges, security, and transmission, with the AEM EMS controlling all of the engine controls. I added a fuel return and a Deatschwerks fuel pump, so it is now a return style system with 660cc injectors. It literally drives like a stock turbo car that makes around 320 at the wheels on 6 psi through FACTORY exhaust. With the cutout open and 8 psi, it is probably a good 40-60 hp more than that, through the factory auto transmission, that has only had a secondary cooler added to it.
Using GTE pistons and rods, GE VVTI head and GTE headgasket, compression is around 8.8:1, give or take, I get 175 psi across all 6 cylinders. The car is quite the little monster. I am only waiting on building the transmission to be able to up the boost and make serious power...
Both fo you thank you very much. I want to do this research before I go crazy and get into something I regret. I understand the EVO for the money makes great power, I just don't want to own the car anymore. I am a Toyota Guy by nature, iv had my far share of Supras now and I wanted to see what the lexus could provide me with.
MBH123
IS - 1st Gen (2001-2005)
06-05-16 09:23 AM
