IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Wider tires on the rear
Old 01-13-13, 09:15 AM
roly1983
roly1983's Avatar
Default Wider tires on the rear
Hello,
I own a 2004 is 2000 manual, with standard tires/rims 215/45 R17
I would like to install wider tires on the back, both for looks and better grip in the back.
What size can i use in the back, with the standard 17 inch alloys?
Thank you
Old 01-14-13, 05:48 AM
ais300c
ais300c's Avatar
you can go as wide as like 234 or 245, i mean it would bow out off the rim like a sob but up to you.
Old 01-14-13, 09:09 AM
roly1983
roly1983's Avatar
So basically i have to stick to the standard tire size. :-(
Old 01-14-13, 01:24 PM
ais300c
ais300c's Avatar
well i think our rim is a 17x8 which you could change to like a 225 all the way around which would improve stability and traction. It's all about what YOU want i did a staggered fitment on some 18x8 rims i had a 255 on the rear but the tire bowed over and I rolled my fenders to prevent rubbing. remember modifications are never simple. ever.
Old 01-15-13, 06:58 AM
TheDane
TheDane's Avatar
I have 225 in the rear at my stock 17x7,5" rims. On my Sport Cross they are only 17x7" in the front. Thought all IS was like this in the front I drive with 215.
Old 01-15-13, 05:00 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
All IS300's have 17x7 all around, except the SportCross, which has a 17x7.5 in the rear...
235/45-17 fits ok on the stock wheels, any wider and its too much...
Old 01-15-13, 06:06 PM
ais300c
ais300c's Avatar
yeah I couldnt remember if they were 17x7 or 17x 8 thx for clearing that up mitsu
Old 01-16-13, 09:47 PM
edgy
edgy's Avatar
iirc they came with 215 series tires,... you can easily run a 225 and or even better a 225 up front and a 235 out back ... BESTEST... ( using OEM parts.).. running 235 on a larger sportcross rear wqheel....
voleduy
08-27-13 05:37 PM
iameric
07-16-09 07:18 AM
maschronic
RX - 1st Gen (1999-2003)
02-27-07 12:10 PM
Jmai22
Wheels, Tires & Brakes Forum
11-02-04 11:48 PM
chowder
Suspension and Brakes
03-17-01 05:54 PM
Quick Reply: Wider tires on the rear
