IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
another AUX problem
Old 03-03-13, 03:02 PM
jetskiwill
jetskiwill's Avatar
Default another AUX problem
went looking for solution to play iphone/mp3
this was the cheap solution I found
http://www.ebay.com/itm/LEXUS-iPOD-i...2ed8df&vxp=mtr
super simple to connect.....uses factory connection at the back.
only problem is IT NEVER WANTS TO WORK!
after 2 hours pressing buttons, inserting Cd's, removing, holding CD buttons I could only get it to play twice
anyone exprience the same?
anyone know the button combo to get it to play everytime?
Old 03-03-13, 03:13 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I think your problem is that it is cheap and good chance it just doesn't work well with your car...
Grom Audio - search for their kits, they work perfectly every time...
Old 03-04-13, 07:22 AM
jetskiwill
jetskiwill's Avatar
yeah....looks like a ok option but it uses regular 3.5mm connection.
I might as well use a tape deck player if Im going to do that and save 70 bucks.
seems like if the cheap one can make a iphone connection, a more expensive reputable company could make that connection also.
Old 03-04-13, 07:38 AM
jetskiwill
jetskiwill's Avatar
additionally....I dont understand the point of blue tooth.
using my tapedeck connected to iphone....I get calls, the music stops, anwser, and voice is projected through the car via 3.5mm to tape deck....they can hear me because the phone is in the car.
the addition "blue tooth" sounds like a load of BS to me.
The more I think about it, GROM is a waste. If I want a 3.5mm connection I would do the even cheaper DIY method with a relay. and charge it via the ciggerette lighter.
Old 03-04-13, 03:58 PM
BiggDatty
BiggDatty's Avatar
I use an FM Transmitter lol 10 Dollar one off of ebay, and it works great.
Old 03-04-13, 07:10 PM
mitsuguy
mitsuguy's Avatar
What????
If you get the 3.5 jack one, yes, but if you get the ipod or usb controllers, then you can control directly from the factory radio... yes, the factory radio will control a usb stick with thousands of songs in hundreds of directories...
When you say tape deck, do you mean like a tape deck adapter??? where you put the fake tape in the stereo? The audio quality on those is trash, same as with am/fm adapter... With the Grom, there is no hacking, if they say it works for your car, it works, and it works like it came that way from the factory... of course, if you want nice, you have to pay for it... Just think, if you would have saved $40 on some ebay junk, you would be on your way to a Grom unit...
patelxyz
12-19-17 12:15 AM
LenniePaz
04-30-12 01:23 AM
da-bizket
06-17-08 09:53 PM
Airwolf
09-12-06 01:17 PM
RodF
13
09-05-01 09:23 AM
Quick Reply: another AUX problem
